ANYONE???
Last night we had a look and the GTR plugs is exactly the same as RB20DET? and the same pin is blank on both! Just wornding if we can match them up the same as the RB20 to Z32 diagram says???
Is the GTR AFM the same as RB20 except its 65mm insteed of 80mm???
thanks
Don't know about GTR wiring, but I can tell you about Z32 pin connections.
There are provision for six pins, from left to right looking at the connector they are A to F. some Z32s only have only four pins, with the two end pins missing or blank on a standard six pin Bosch connector.
A/ no connection, the pin may not even be there.
B/ output signal, about 0.5v no flow, to +5v max air flow
C/ signal ground, usually connected to screen of signal cable going to ECU
D/ power ground
E/ +12 supply from ignition switch
F/ no connection, the pin may not even be there.
Just check with a multimeter the voltages on the air flow meter you have now. Only four pins, two should be ground, one has +12, and the other a small signal voltage.
They will either be the same, or different. But either way you should be able to figure out where the wires should go without too much trouble.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
