I am planning to change the gear oil in my R33 GTS-T. I have already purchased the 1 gallon lightweight redline oil.
I have an empty 1 litre VMX80 bottle that has a little hose attach to the cap. Can I use this bottle to fill up my gear box without a pump? (some people mentioned to use a pump to fill it up)
https://www.sau.com.au/forums/topic/13827-change-the-gear-oil-without-a-pump/
  • 4 months later...
Not sure to tell you the truth. I haven't ever tried it this way.
I managed to get a 1/2 inch torque rench to the filler and drain plug. Gave me heaps of leaverage to get the nuts loose. I still almost spat my guts out my bum cause the nuts were so damn tight though !!!
I 'think' you'd have to take the gearstick surround off, then the 4 bolts around the gearstick. Then that might open up the hole which may let you get a hose down there and put it in the filler hole. Then just use a funnel thingy to fill it up.
Just don't spill the oil inside the car !!
J
I think someone was saying that you can fill it up via the speedo cable plug if you can't get the filler nut out.
Just undo the speedo cable and pull it out, then do it that way.
Not sure if you'd be able to fill it up from inside the car if you use the speedo cable way though...
J
guys, the best way to fill it up is : after u drain it from the bottom plug put that plug back then take the filler -level plug out on side of the b/box and use a pump to fill it up ( i use compressed air to pump it up there ). if u want to get to it from the top this is how the gear stick comes out .
take the trim mould off , gearknob off , boot off , ( u need new cable tie to put back )then there is a c-clip that u have to take off ( u need a long nose to sqeeze it )once u take that off the gear stick just comes out .
warning here though u won't know when its full unless the filler -level pug is out but even then if u fill from there i'm not sure that it will go in to the box on gtrs 4wd 's it won't, it will end up in the trasfer case .
don't bother doing it this way besides u should be able to take the plug out so u can check the level everytime u do a service so u must be able to take the plug out .
u need a long wrentch ( like 300 mm ) with a 1/2 inch drive ( or maybe 3/8 cant remember ) its shouldn't be that tight i never have any trouble undoing it .
Read the link
I did this on two cars on friday, one through a stupid little hole and one through the speedo sender.
USE the speedo sender hole instead of the normal filler hole if u cant get it undone like me :) its a hell of a lot easier, and you get the correct level too.
hmm not the same gearbox, but last week i changed clutch and gbox oil in my other car, damn filler plug was rounded off and so damn tight, the only way i got it off was to take the whole box off and weld a long bar to it to break the seal. total pain in the arse!
as for filling it without a pump, get a length of hose (about 3 meters) that is big enough to fit in the filler plug hole but so its loose. and get a funnel. stick these two together by what ever means neccesary.. silver tape works good to seal it.
put one end in the filler hole and the funnel end above the car (may have to attach it to something unless you feel like holding it there) then through gravity the oil will flow down into the box slowly. if you know how much to put in fine just put that in, but if not just keep topping it up untill it runs out the filler hole and then let it drain till it stops then replace plug
how do u know when u have just the right amount if u dont undo the level -filler plug ??
how do u check the level if u dont undo the plug when u do normal minor service ?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
