Thanks for the info guys. Turns out it was indeed the subframe bush. Quoted $600 in labour alone! Sheesh.
This product here, is this what I'm after?
http://cgi.ebay.com.au/Bee-R-PINEAPPLE-BUS...1QQcmdZViewItem
Cheers
Andrew
Thats definitely pricey.
You can pick up a set of Nolatec Subframe bushes for $190 from UAS. The local workshop who has installed subframe bushes before wants $200 to fit them. :P
They are fairly easy to do your self providing you have 'some' tools. Remove the subframe, big hole saw to drill the old out, press the new in. An ebay 12tonne press for $150 will do the trick.
Then if you wish throw some pineapples in to angle the cradle for traction if you wish.
The UAS Link.
http://www.nismo.com.au/pricelists/priceli...esuspension.htm
Scroll roughly half way down or do a search for subframe bushes.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
