Wanted: HKS EIS
Hello Danny,
I couldn't find your email address so I will have to post in the forum.
I saw your message and contacted head office in Japan about your query and have been given these answers:
HKS EIDS 12,123 yen
HKS EIDS Pro 17,048 yen
I am not sure if you are still looking for the product however if so we have them available here:
http://www.greenline.jp/catalogue/btlist.p...ype=electronics
If you wish to visit our website to see further information we can be found at http://www.greenline.jp.
For any further information, I am located in Sydney however contact me anytime at [email protected]
I hope this helps your queries,
Regards,
Simon
https://www.sau.com.au/forums/topic/13918-wanted-hks-eis/#findComment-279829
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
