I've checked all the fuses and every cable seems to be connected....
does anyone know a good Line sparky i can go to???
thing is all other dash lights work fine... i'm getting sick of driving at night with my phone light shining on teh speedo.
teh suxor IMO
kthnx
https://www.sau.com.au/forums/topic/139335-instrument-cluster-lights/
Maybe the bulbs in the cluster have shat itself? or the fuses in the actual cluster have blown?
Have fun taking the cluster out. :laugh:
I'm getting sick of driving at night with my phone light shining on teh speedo.
Not to mention illegal.
i dont know about 33's but on a 32 if the dimmer is unplugged then the dash lights wont work.. give that a check
happend to me, all other lights worked cept my speedo.. Locate the dim switch, it may be broken. I've just taped the 2 wires together.
Same here....
It still bemuses me that manufacturers ever bothered to put a dimmer switch in cars anyway.....
Why the f uck would you not want to see what speed your doing?
Anyway, check that, it's the most common problem.
The switch on mine was very tempremental....
Hey champ, had this happen in my s15 once, and thats cause the car runs so low, that the wiring harness to the fuse box got split, as the tyre scrubed out one of the wires which was the lights for the dash.
Have a look under your wheel arch at all the wiring harness that goes to the fuse box, this might be your problem :laugh:
FAIL!
that is 100% NOT correct, theres no such thing.. The wires are direct and do not come from under the car.
Rember that your car is a S15!
i dont have one ether.. hmm
marss, check the usual. cluster plugs at the back, there is 3 there. also the parker fuse in the boot. and of course, the globes them selves, might of had a short and blown them all? duno. but not hard to check for once the cluster is out. its not hard, easy enough to pull out in 15mins or less.
Mine didnt/doesnt have one. :)
I think they changed the law or something. :P
neither does mine... it's been taken out.. there is a high chance that a previous owner had taken it off..
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
