hey guys ive decided to post up my r34 for sale. This car is not registered however has been complianced ready to register. Car was imported less than 2 months ago.
Details:
98000kms on clock
bodykit wif aftermarket front bar
black bonnet
nismo panel filter
17"inch gold wheels
nismo gt wing
tiptronic transmission
other then the basics on the exterior the car is pretty much standard everything
car drives very well, very smooth no problems what so ever.
just got the car detailed inside out so came out pretty good.
not a scratch on the car
lookin for around 23,000ono now 22000ono.. MAKE ME AN OFFER
Now looking for 20k FIRM Non negotiable
contact daniel on 0402365228
located in mill park
Edited by dani3l
ok guys, as mentioned earlier i am goin overseas for a few weeks, im dropping the price to 22,000 ONO, so if anyone is interested give me a call, im leaving next thursday..
cheers
daniel
ok guys, as mentioned earlier i am goin overseas for a few weeks, im taking 1000 of the price to 22,000 ONO, so if anyone is interested give me a call, im leaving next thursday..
cheers
daniel
  • 2 months later...
hey guys, car is still for sale, havent had time to readvertise and update the thread. Car is still in same condition etc, sitting in my garage for a while. Looking for 21,000neg
Yeh needa get rid of this one dude.. my new one just landed in aus not long ago, so this stocker needs to go. Yeh read your forum man 15000 huh, my 33 was similar basic mods and got 14500 for it. The markets flooded man hard to sell atm.
Il ask around :D
yeah bad its the worst. ill let it go for 14,500 but thats its i sell it soon.
Goodluck with ur sale man, ur next car will be mental :D
