Hey guys,
i just bought some wiseco forged pistons 87mm bore (rb25det), now on the wiseco site it says that these pistons bring comp ratio down to 8.0 to 8.4, my question is what size head gasket to get, acl only make a 1.2mm one. im going to be running a gt3040, power fc, q45 afm. i want to run bout 25psi max just worried that a 1.2mm head gasket wont be enough but would the pistons bring the comp ratio down enough to do this.
https://www.sau.com.au/forums/topic/139399-compression/
Thanks Craved, tried using that calculator and couldnt figure it out. Bit unsure about the CR.
Is there anyone else that has done similar mods? Just want to know if i can use the 1.2mm head gasket safely on this setup...
run the 1.2 headgasket
run the 1.6 or 1.8 if you wanna lower the comp
Decking the block and machineing the head also make a difference by raising comp
if ur are decking the block as well as machineing it run a 1.4 or 1.6mm thick headgasket
Edited by MR331307
https://www.sau.com.au/forums/topic/139399-compression/#findComment-2598570
  • 4 weeks later...
I have also orderd wiseco 40thou pistons. Still confused as to what thickness gasket to uses also. A mechanic told me it is best to use standrard size gasket and get the head machined to suit? I have GT2835pros and will be running approx 22psi. Not exactly engine friendly. Would a comp ratio of say 8.6 be suitable? I want the saftely but also want to maintain the response. Obviously to bring the comp up i would need to machine the head anyways or get a thinner gasket which i think wouldnt be the safes option.
https://www.sau.com.au/forums/topic/139399-compression/#findComment-2679544
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
