1994 NISSAN SKYLINE 5speed manual white with purple flames on the bonnet.
is a 2.5ltr turbo done 115000klms regularly serviced every 5000ks good clean car need to sell as moving interstate in 3 weeks live in south east melb. engine needs to be put back in dont have time
comes with:
full 400r body kit
exhaust system cat back
blitz pod filter
boost controler
18inch rims
turbo timer
MUST SELL ASAP $8000
CONTACT Chris 0401334464
Edited by slow_as_33
is a 2.5ltr turbo done 115000klms regularly serviced every 5000ks good clean car come with a spare head need to sell as moving interstate in 3 weeks live in south east melb.
comes with:full 400r boddy kit
blitz pod filter
boost gauge and controler but car never boosted didnt get round to it
18inch rims
blitz frount mount
aftermarket cpu a gredy e manage blue for an extra $350
turbo timer
stereo:pioneer 6 stacker cd/dvd player
6 inch pioneer splits in front door
clarion 3 way 6 inch in rear
clarion amp and sub in box
MUST SELL ASAP $10500
bump
Has the car been guttered? Back right wheel looks like its running +3 degree camber..!
no the wheels on it are 255/35 18s have never been guttered i just need to get rid of it a motor has just been put in recently rebuilt 300 ks agodid have 220 kw at wheels with last motor had troubles with it so there is a standard motor in it runs fine now
comes with:
full 400r body kit
blitz pod filter
18inch rims
turbo timer
MUST SELL ASAP $9000
this must go now will con sider any offer
comes with:
full 400r body kit
blitz pod filter
18inch rims
turbo timer
must sell leaving next monday
comes with:
full 400r body kit
blitz pod filter
boost controler
18inch rims
turbo timer
car has to go make an offer
Thanks mate it's a good price, my dad is pretty keen after driving my skyline. Your leaving Monday right? Might come and check it out over the weekend if it is still available.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
