Quote from the UAS site:
"R33 GTS-T as featured in Dec Jan Street Heat Mag has high flow turbo full 3 inch exhaust with our Marco muffler nice note but quiet, Apexi Fuel and Ignition Controllers, 02 Rush Ram Pod, Uniglide and is a real 163kw at the wheels on Dyno running 12pounds boost."
Now, DONT GET ME WRONG HERE - I AM NOT DISSING UAS!!!!
But, doesn't that power output seem a bit low? I mean, its got high flowed turbo and a few other goodies and its making the same power as my car at 9psi, when it is running 12psi? and i dont have a high flowed turbo, or ignition controllers...
My car has 3 1/4" to 3 1/2" exhaust with a high flow cat. 9psi, large front mount I/C, and some other bits and pieces (including iridium plugs) and i made 162rwkw...
anyone else think this is a bit low?
Christian.
https://www.sau.com.au/forums/topic/1398-poor-performamce/
Did it say if it had a fmic or HiFlo Cat?
I only get 152kw at 0.6 bar (just under 9psi)
But I dont think it was dyno tuned properly, my car is an
auto and they tuned it with o/d off, so its like tunin a 5sp
manual in only 4th gear.
My mods are Cat Back, Apexi Power Intake, Turbosmart Boost Cont, Apexi SAFC. Still runnin stock IC. I wonder is a fmic and hiflo cat will give me that extra 10kw ...
But I still tink its bec it was tuned with o/d off thoe ...
https://www.sau.com.au/forums/topic/1398-poor-performamce/#findComment-27829
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
