1993 Nissan Skyline R33 Series 1
Metalic Blue colour
Larger turbo
Stage 1 Nissan Cams
After-market computer (Apexi Power FC)
Apexi AVCR (Actuator Valve Controller - Boost Controller)
K&N Pod filter
New air flow meter
FMIC with custom plumbing
front strut bar
d2 coil over suspension
off set caster bushes
fully adjustable camber control
Nismo LMGT3 limited edition (genuine white) (18'' x 9'')
3'' Momo CBE
HKS SSBOV
Lightened chrome molly fly wheel (4.5kg and brand new)
Exedy sprung button clutch (brand new)
Interiorhttp://www.skylinesaustralia.com/forums/index.php?
Apexi Power FC
Apexi AVCR (limited edition black)
Razo Turbo Timer
Momo steering wheel
Dual gauge pillar (A/F and Boost gauges)http://www.skylinesaustralia.com/forums/index.php?
Genuine V spec GTR dash cluster
Body
Nismo clear side repeaters
Full GTR body kithttp://www.skylinesaustralia.com/forums/index.php?
LED rear lights
Razo shifter
Razo pedals
Sound System
Clarion type r 6'' splits front and rear
Clarion 330watt AMP for splits
15'' POLK Momo Sub with custom box in boot
Sony 1400watt AMP powering Sub
MOngoose 10,000 Alarm/Immobiliser
Addiotnal Info
Tuned by Dale at Castle Hill Exhaust. Ran at 260HP at 7psi, has loads more potential only limits are the injectors which could be sourced. Has small dent passanger door, and minor scratches and stone chips. The additional body parts are not fitted or painted. Taken care of immaculatley and only put on 12kms in 2 Years. Total of 113k kms.
Rego till July next year and just serviced 3 days ago and every 4 thousand kms. Oil used is only REDLINE and fuel is only ever Either BP Ultimate or Vortex 98 Octane.
Very reliable and has never broken down on me, reliable and fast car in one.
Extra
Brand new power window motor and regulator (installed)
Brand New Clutch (installed)
Blitz Brake Pads (installed)
New battery
Flush mounted boot (no wing)
2'' wider front guards
Drift bonnet with vents
serviced every 5000km (oil and filter)
reciepts for over $15000 worth of work, but much more spent.
Price
$21,000 Negotiable, Willing to hear reasonable offers too.
PRICE DROP $20,000
PRICE DROP AGAIN - $19,500
Possible swap for good quality S14a
Located in Wollongong, NSW...
Contact me via PM if interested or any Q's.
Edited by jakegts
https://www.sau.com.au/forums/topic/139936-sold/
PRICE DROPPED TO $20k
Also willing to:
Remove NISMO LM GT3 Rims to stock or
Remove Stereo to stock or
Remove spare fibreglass bonnet, spare fibreglass sidefenders, and spare fibreglass flush mount boot
in an effort to reduce price.
If potential buyer would like all items removed for a cheaper purchase price please PM me or just PM with an offer, will take into consideration.
Edited by jakegts
https://www.sau.com.au/forums/topic/139936-sold/#findComment-2635186
Also willing to:
Will you sell these seperate now?
https://www.sau.com.au/forums/topic/139936-sold/#findComment-2636356
  • 2 months later...
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
