same shit... different flavour.
the more cars I see with the "omg hektik driftzor look" the more I care less for each variant...
I'd personally go the vertex one, as its the original driftzor look, plus its the most subtle one that actually suits the car instead of making it looks like a S13 that look like an S14 that looks like a chaser that looks like and R34.
