Cleaning out the garage and have these parts available. Al parts from a '95 GTS-T.
Rotors, calipers and pads $500
Power Steering Rack $100
Drivers door with mirror white excellent condition $200
Rear seats $50
Front 5 stud hubs $??
Added:
Engine cross member $100
Rear glass with wipper holes $100
Rear quater glass $30 each
Rear bumper rio $100
All items are in Melbourne and prices are negotiable.
email: [email protected] or PM
Edited by Blitz_boy
Rear seats $50
All items are in Melbourne.
email sent.
Rear seats $50
Added:
rotors calipers and pads still available? front and rear? would you post them? and could i see some photos please
Edited by DaGr81
I don't want to seperate the motor from the door, sorry.
Don't want to post the brakes as they are quite heavy, and there is already allot of interest localy.
pics will be up shortly.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
