First start after my RB2.4 rebuild
Guest JOnJ0n
Whats up, I recently just rebuilt my RB2.4 kit engine and when my HKS 264 cams for both intake and exhaust where installed they where installed at stock setting by the RB2.0 service manual. Now when I cranked my engine my car was making a tapping noise from the head, almost like the valve where hitting something or some of the hydraulic lifters went bad. Now the thing about this head is it was already on my RB2.4 engine before and the only thing that was taking out of the head was just the cams, all the rest of the internals of the head stayed inside (ex. valves, springs...) Now if my HKS 264 cams where set at stock settings do you think it would cause my valves to hit something? If so do you think it would cause any damage for about 10mins worth of running all together. Also I looked up my cams and I saw my cams should be set at 110 degrees for the intake and 115 for exhaust and stock settings are 0 degrees. Soooo do you think the stock settings would cause my valves to hit something? Any help would be appreciated... Thanks
https://www.sau.com.au/forums/topic/14026-first-start-after-my-rb24-rebuild/
its highly possible for them to be hitting pistons. Your hks cams would be a higher lift cam, therefore would require the appropriate dial in (110 and 115 degrees)
The cams may also have longer duration and/or advanced or retarded slightly.
would pay to check your lifters too, remove them and compress them fully, then refit them
get a pair of hks adjustable cam gears. the tapping sound would most probably be valves on pistons. i dun think there'd be any damage if u didn't drive hard. but would get it checked out anyway. correct me if i'm wrong but i think u'd need a set of valve springs and retainers for those cams to be on the safe side.
Guest JOnJ0n
Well the head I am using now was on the RB2.4 before I had to rebuild the engine and nothing has been change. I also ran the same head on my rb20 with the same setup just a RB20 engine. So I guess my main question is -
On a HKS website is said for a RB2.0 for the intake cam the Designed Valve Timing is 110 and for exhaust is 115. So do I set my main crank pulley at 70 degrees clockwise from 0degree TDC (for intake cam) and then make sure my #1 cyclinder cam intake valve is full open? and then set it back to 0 degree mark for TDC and turn the main crank pulley counterclockwise to the 65 degree and then make sure the #1 cyclinder exhaust valve is fulley open? I am new to this whole timing from scratch with aftermarket cams =( sorry, but any help is helping me...
i'm not too sure about that. you'd have to get it checked out by a proper mechanic cos the stats are for a 2 litre block and you're obviously a 2.4 litre. you'd be better off putting the car with a good mechanic and getting the thing sorted. gives you peace of mind as well. btw r u really in okinawa? if u're in japan, i dun think locating a mechanic would be a problem.
Guest JOnJ0n
Ok I also have some other questions. I talked talked to my tuning shop that also had a RB2.4 car and I asked them about my 264 cams and if they would hit the pistons being set at stock 0 degree timing and they said no. So I was going to try something else that one of my friends told me about his 550cc injectors making a really loud noise. So I disconnected the fuel pump and the injector box and turned my car over. I didnt hear any tapping noise. Do you think if my valves where hitting that I would hear it then. If I didnt hear any tapping when I did that check what else could that loud tapping noise be? Another told me that one of his friends car had a loud tapping noise also and they found a oil drain line or hole clogged. Could this really cause a loud tapping? Any ideas would help. Thank you =)
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
