  • Replies 78
Corners are where the funs at ;)
There's a really cool hairpin at the end of the strip.
Every time I get there, I'm always tempted to just rip the car into that perfectly paved, wide open, 180 degree bend and just try and drift through it. ;)
https://www.sau.com.au/forums/topic/140333-wsid/#findComment-2615339
it should be good having it both days.
hopefully have some time next weds to go down for the first time, anyone going next weds? if anyone sees me in a stock looking white r32 come say hi
dead32 all the prices and stuff are on the WSID website.
https://www.sau.com.au/forums/topic/140333-wsid/#findComment-2615555
No ET limits, just 95db (track) noise limit.
"EVENT DETAILS:
FULL THROTTLE FRIDAYS
RACE FOR REAL – Starts Friday, November 3!
The Only Limit is Your Imagination.
Gates Open 5pm
Spectator Gates Open from 5:30pm
Racing 7pm-midnight
Video Screen Music, Cranking Atmosphere!
Pricing:
Competitors - $45
Spectators - $20
Kids Under 12 - FREE!
Location Information:
Western Sydney International Dragway
Ferrers Road, Eastern Creek
Web: www.wsid.com.au
Phone: (02) 9672 1320
Email: [email protected]"
All info here:
http://www.wsid.com.au/default.asp?Page=Article&ID=305
https://www.sau.com.au/forums/topic/140333-wsid/#findComment-2618744
Every time I get there, I'm always tempted to just rip the car into that perfectly paved, wide open, 180 degree bend and just try and drift through it. :rolleyes:
I get the same urge..
on my last run out there i left the window down.As i was driving back one of the fire officials called me in and lectured me on the non-saftey and how my arms are prone to flying out in the event of an accident.I totally agreed with him,and diddnt argue the point.I diddnt even point out that if their officials were doing the job that they were supposed to be doing that i wouldnt have had the problem in the first place.lol.sad but true :P
https://www.sau.com.au/forums/topic/140333-wsid/#findComment-2619025
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
