For Sale , White R34 Nissan Skyline GTT
1998 model, RB25DET, MANUAL
Aprox 79k
Price dropped to $26500 due to mini crack in front bumper.
Price Negotiable.
Performance Modifications:
Custom 3inch exhaust with 4inch tip
Catbak
Blitz airfilter
Front mount
Down pipe/dump
Kmac suspension
4 extra large NISSAN calipers
Strut bars
Exterior Modifications:
Front Bumper GTR replica
18inch Rims
G3 Potenza Bridgestone tyres
Western Australia
Perth, [email protected]
0403-636-252
Harry,
Edited by harrymabob
https://www.sau.com.au/forums/topic/140458-r34-gt-t-forsale-sold/
Steering wheel makes a little click noise when i turn the wheel?
Just happenend today.. anyone no the reason why ? or how i could fix that?
PRICE OF CAR DROP TO $25 000
Quick OFFERS PLEASE :laugh: probz cheapest around!
Message me if u wanna come see the car! :)
Hoping to Sell this car before November 18th ,
Going away for holiday, rather sell car, than letting it stay in the garage for a couple of months.
Please make me a reasonable offer, and come see the car :D
any mechanical probelms ie, engine?
why you selling it? and why is it so cheap ?
no, no problem just pure rb25det! :)
one of the reason im selling it and for that price, coz i want to sell it before this month, im going away for a couple of months, no point leaving it in the garage when im going to sell it when i come back anyway.
main reason, parents dont like the car, to fast.
  • 4 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
