Its difficult to justify the cost of a HKS3037pros when Garrett now do their GT30's and GT35's in internal gate.
Cheapest bloke I've came across for turbos is Roguepi or I believe his alias is Amosite or something on this forum.
http://stores.ebay.com.au/ROGUEPI_W0QQcolZ...3QQftidZ2QQtZkm
Keep an eye out for the internal gate gt30's, they tend to go pretty damn quick.
my car made 301rwkw at 1.4 bar with the hks gtrs.. spool alot quicker than the turbos mentioned above..ya will need big cams though..
hi mate what sort of big cams did you get?im also getting a GTRS soon. cheers louie
The RB25's are tough nuts providing they are tuned well..
They appear to hold together much better when the comp ratio is dropped a little via a headgasket.
thizzle... Are you still running stock 9:1 comp? If so thats damn impressive and credit goes to the tuner. :(
