But if you are planning on sticking with the std turbo....i would be very interested to see an engine that actually has more mid out of it. Does anyon ehave graphs of before and after?
Even with NickR33s results...im not convinced. The std turbo isnt that big for a 2.5L and i doubt they can provide the airflow to really need cams to help fill the lungs.
If NickR33 picked up some grunt...i woudl then ask did he have the SAFC tuned before the cams were installed?
Not being argumentative, just curious to see if we can rule out some other things :P
I used to have a before and after graph, it was about 15-20hp up in the mid range. The top end was improved also but, without access to the timing maps (S-AFC II) the top end had to be left alone.
I picked the HKS exhaust cam as it was spec wise pretty close to some advice I got from someone in the cam making game.
Ok, thats interesting then. I know of a few examples that did nothing with cams. One i read about and another was a friends R34GTT which actually lost power with the std turbo. It wasnt until he got the high flow goign that it shined.
Perhaps there is more to it, i stand corrected :P
No Roy,
You are right about over-caming the motor ,the main issue is going over the top on the inlet side with such a small turbo. The R34 Neo motors have a better profile set of solid cams than the hydro- R33 ones.
I used step 1 HKS 264deg 9mm lift exhaust cam and the factory inlet.
Hey,
Cams are good, especially poncams which do not need heavier spring, valves, or having an aftermarket computer in.The Poncams are designed to bolt on and drive off...not even cam gears are needed.0 adjustment works the best for them.
If this is the only modification you are planning in the next year or so ...do it because you will get great results.
Hope I have been of some help..
Cheers :P
These cams are around $800 for the set and installation should be around $400.
Your power output will increase slightly, but your response and power curve will be alot better.
Where do you get poncams for $800?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
