Flying Performance International is the only official online Hybrid & SABER dealer
Flying Performance International official website www.flyn.com.au
Check out the Hybrid & SABER official website at www.powerdigger.com
FLYING PERFORMANCE 3" DUMP AND ENGINE FRONT PIPE IN ONE, because it is a Flying 3" mandrel bent dump & front pipe in 1, not just the front pipe that other people sell, WE GUARANTEE MASSIVE POWER INCREASE OF UP TO 50 PS!!! If you have a boost gauge you can see the 2-4psi improvement and the better throttle responsiveness. VERY LIMITED STOCKS! HURRY!!!
We have the following models available:
s13 / 180sx ca18det
s13 / 180sx sr20det
200sx s14 / s14a / s15
r32 2.0L gtst / gtsr
r32 2.5L gtst / gtsr
r33 gtst / gtsr
$225 delivered
OPTIONAL PACK
FLYING PERFORMANCE NEW 6 METERS HEAT SHIELD EXHAUST WRAP KIT INCLUDING STAINLESS STEEL RACING CLAMPS $35
This pipe will give you 2 - 4psi increase depending on existing boost pressure.
Payment Instruction
Postage & Handling = $15 freight Australia wide
PAYMENT TO : FLYING PERFORMANCE INTERNATIONAL PTY LTD
ST. GEORGE BANK LIMITED
BRANCH NO. : 112-879
ACCOUNT NO. : 065766824
PLEASE you must give the bank your forum user name as the description of the transaction. That way it shows up on our bank statement with the amount you have sent us. So we can match your order with your payment otherwise there may be a delay for us to match the payment to your order!
After you have made the payment, please you must e-mail us with your payment date & amount, your name & postal details.
Once we receive your payment, we will inform you and send it at the same time.
It will be packed and sent securely in boxes or bubble padded bags for best protection.
Optional extra
7f_1.JPG $48 SABER stainless steel mesh air filter
41_1.JPG $180 SABER 60mm electonic smokey lens gauges
59_1.JPG $259 SABER GDB WRX /STi air intake kit
cf_1_b.JPG $49 HYBRID a set of 10 HOSE CLAMPS, 2.5", 2.75" & 3"
f0_1_b.JPG $19 HYBRID SILICONE HOSE REDUCER, We have 3" - 2.75" / 3" - 2.5" / 2.75" - 2.5", you tell us the size you want.
0a_1_b.JPG $17 HYBRID SILICONE HOSE, 3" / 2.75" / 2.5" / 2.25" / 2" / 1.5" STRAIGHT HOSES
53_1.JPG $7 FLYING SILICONE VACUUM HOSE
12_1.JPG67_1_b.JPG $49 Flying bov
05_1_b.JPG $49 Flying boost controller
7b_1_b.JPG $29 Flying boost controller
5c_1_b.JPG $199 + $25 extra freight
4e_1.JPG $33 FLYING 6 meters EXHAUST HEAT WRAP
06_1.JPG $149 Flying sr20det turbo manifold (SOLD OUT)
0a_1.JPG $189 Flying Rb20det / rb25det turbo manifold
dd_1.JPG $149 Flying 180sx s13 r32 300zx camber arm
e3_1.JPG $149 Flying s14 s15 r33 r34 camber arm
b8_1.JPG $139 Flying GT wing
72_1.JPG $99 Bee*R PINAPPLE BUSHES S13 180SX S14 S15 R32 R33 R34 Z32
5d_1.JPG $75 FLYING S13 180SX S14 SR20DET SILVIA SHORT SHIFTER
26_1.JPG $79 FLYING SILVIA S13 180SX S14 S15 SR20DET TURBO DUMP PIPE
fe_1.JPG $99 FLYING SKYLINE R32 R33 R34 RB20 RB25DET TURBO DUMP PIPE
55_1.JPG $55 FLYING ADJUSTABLE FUEL REGULATOR
7b_1.JPG $25 FLYING OIL CATCH CAN
HSD Suspension
HSD coil-overs are used by 2005 Drift Australia champion Darren Appleton and many other prominent drivers in Australia. Now available only in the premium HR series, HSD coil-overs feature 55mm heavy-duty full-tapped dampers with 15-step damping adjustment. All models feature pillow-ball top mounts for easy installation and maximum control. Models with strut-type suspension also feature camber adjustment, while all models feature adjustable base height and spring seat height.
HSD coil-overs are supplied with spring rates intended for club-level motorsport, drift and street driving. Harder or softer springs are also available at just $100 a pair. All rates from 3kg/mm to 14kg/mm are kept in stock.
All HSD coil-overs come with a 12-month warranty against manufacturing defects.
NISSAN
S13 Silvia or 180SX $1549
S14 200SX $1549
S15 200SX or Silvia $1549
R32 Skyline GTS & GTS-t (GTS-4 available to order) $1549
R33 Skyline GTS25 and GTS25t $1549
R34 Skyline GT and GT-t $1549
R32 GT-R $1549
R33 GT-R $1549
R34 GT-R $1549
Z32 300ZX and Fairlady Z $1549
Z33 350Z $1549
TOYOTA
JZX90 Mark II, Cresta, Chaser $1549
JZX100 Mark II, Cresta, Chaser $1549
JZA70 Supra (Also GA-70, MA70, MA71) $1549
JZA80 Supra $1549
SXE10 Altezza and Lexus IS200 **NEW** $1549
SUBARU
GC8 Impreza WRX (MY94 to MY00) $1599
GDB Impreza WRX (MY01 to MY02) $1599
GDB Impreza WRX (MY04 on) $1599
SG5 Forester $1599
MAZDA
FC3S RX-7 (Series IV and V) $1549
FD3S RX-7 (Series VI to VIII) $1549
MITSUBISHI
CP9A Lancer Evolution (IV to VI) $1549
CT9A Lancer Evolution (VII on) $1549
HONDA
EG Civic $1549
EK Civic $1549
DC2 Integra $1549
DC5 Integra **NEW** $1599
AP1 S2000 $1549
This wrap will work on any make or model of cars, if you can wrap it you can use it! This wrap can even eliminate turbo lag!
You have seen it in proper race cars like V8 Supercars and JGTC in Japan, and now we bring it to the street, introducing the FLYING Exhaust Fiberglass Wrap. It is a weave of the finest insulating fiberglass material with extremely closed texture pattern. The type of fiberglass we are using to make the Exhaust Wrap is carefully examined and tested in our overseas development centre to ensure it will last over the vehicle's working life for reliability and durability. It keeps the heat in the pipe and at the same time protects the electronic components in the engine bay.
V SPEC RRP AUD$350+
Flying Performance SPEC S Alloy BLACK GT Wing
53" (1.4m) length, 7" (18cm) height, 15" (38cm) between mounting legs
* UNIVERSAL FIT for most cars in the market. Good for both sedan and coupe.
* Hi-tech styling, LIGHT WEIGHT but STRONGER in structure than fiberglass and ABS plastic.
* Street cars don't have slicks tyres, this GT Wing makes it up with extra downforce
* Made specifically for hard tuned street racers to provide extra stability and tractions for all cars
* No painting required but PAINTABLE easily without any sanding / preparation (both 2Pac, acrylic).
* EASY DIY INSTALLATION, you can install the wing in as little as 30 mins.
* Don't be the last one to get it in the block and have the FAST and the FURIOUS, TOKYO DRIFT look.
Brand new FLYING Rear Camber Arm Kit RRP $199 Now $149
Adjustment up to -3 to +3 degrees
Available for for the following models:
* NISSAN SKYLINE R33 GTST, R33 GTSR, R33 GTR & R34 GTT & R34 GTR (Both RB25DET & RB26DET)
This FLYING Rear Camber Arm Kit (FRCAK) is constructed with Grade A+ quality High Tensile Steel with heavy duty spherical pillow ball joints for outstanding reliability, no matter how sideways or which direction your spinning, an easy and a perfect suspension upgrade for circuit racing, drifting or fast street driving enthusiasts. This product is essential for vehicles that are lowered or have increased wheel diameter, it also allows wide range of adjustment for correcting rear camber angle to improve rear traction, either adding negative camber for aggressive driving for track racing / drifting, or adding positive camber to reduce uneven rear tyre wear on inner edge for normal street driving.
This complete bolt on kit includes BOTH left & right sides, full powder coated in BRIGHT SKY BLUE to protect the items. Very easy to install, please refer to the diagram on the right.
We have 3" / 2.75" / 2.5" / 2.25" / 2" / 1.5" straight hoses, you tell us the size you want.
100% Genuine Hybrid Straight Silicone Hose
The best quality silicone hose you can find
3 layers of reinforcement
Each hose is about 3" long
Heavy duty strong structure, best for high heat and high boost pressure application
Very flexible and durable
Best for intercooler piping and air filter intake pipe
We are the only official authorised online Hybrid dealer!!!
Big boost pressures need decent clamps to keep all the hosing in places.
*Latest version stainless steel clamps with T-bolt clamping mechanism
*Can be adjusted by socket and philip head driver
*Attractive looking fully polished
*Unlike other ones in the market, our clamps have no slots, so it wont damage the silicone hoses
*Super light weight and strong in structure unlike other ones in the market
*Multi uses: intercooler piping work, air filter, radiator hose, etc
*Each set has 10 clamps, you tell us the sizes
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
