Hi all , been sniffing around Michelin tyres to find a good balance of reasonable price/best performance .
I stumbled on the newer (2006 vs 2003) evolution of Michelins Pilot Preceda or PP2 and it looks pretty good so far . People say its quieter than the PP1 and its outer tread pattern is supposed to be or work similar to their Pilot Sport tyre . The Michelin Japan site reckons its water dispersal abilities are improved and load balance across the tread is superior . The same person said not quite as sharp a turn in as "brand B" but far better grip and lots of warning at/near the limit of adhesion .
Nuff blurb . My usual tyre haunt sez yes they are around but probably not in 235 45 17 till early next year .
I don't think there will be a 245 45 in 17 but 235 on 8.5 rim should be alright .
Any info and opinions ?
Cheers Adrian .
  • 4 weeks later...
Available now for ~ $235 (235/45/17) . Fantastic extention to the full SK/Whitline suspension kit on an R33 GTS25T . Very comfortable and very high adhesion qualities in my limited experience .. I'll be very interested to see how they perform in wet conditions .
Cheers Adrian .
  • 2 months later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
