Hi!
I have a non-turbo R33 Skyline but bought a half cut which has just arrived in Sydney this week. Will be putting this turbo engine etc into the car and I want to put the red GT side badges on the car instead of the blue ones.
Does anyone know where you can get them for cheap. I looked around and the best I can find is $49 each...
https://www.sau.com.au/forums/topic/141496-r33-gt-side-badges/
Thanks guys! Not sure what I want to do yet, I might leave the badges for a bit, and get some other stuff done that makes it worth whacking those badges on. I have a few more questions about my conversion but don't really know who to ask...
* My LED's in the spoiler and my reverse lights don't work and I can't figure out why??? Don't want to drag an elec into it so thought I might ask someone!
* I want to upgrade the brakes and everything from the 4 stud pattern to the 5 stud etc... I don't want to spend a fortune on it all but I don't know where to get them... Second hand is ok. I'm getting a 1/2 cut from SSS in Sydney and I think it comes with the front stuff but not the rear.
* Where to try and sell the engine and box and other bits when I take them out of my Skyline, all still good but I won't need them since I have the other ones coming.
* Also can anyone reccomend any nice looking 5 spoke mags (and what tyres are good?) I can get because the ones that are on there I don't like and are so hard to clean...
* And, can anyone suggest where I might be able to get a nice full kit (side skirts, front and rear bar and spoiler) from? I looked at J racing .com and I like the Veilside kit but it doesn't come with spoiler...
Well as you can see I am new to all this but I love my car and do want to play with it a little! Thanks for your help.
Francesca :(
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
