  • 3 months later...
Your better off with a AVC-R or a PRofec B.
The PFC boost adapter seem to be featureless and unstable (I remember seeing this somewhere) and cost about the same as any other one...
I run a D-Jetro with a PRofec B-Spec 2 and its been fairly reliable without the 'wank-factor' of the AVC-R :)
' date='4 Nov 2006, 02:59 PM' post='2641432']
I am currently looking at running a power fc Djetro, in my r32 gtr, but what i want to know is if you can run the Apexi Boost Control Kit which is designed for the normal power fc on the Djetro? has anyone do it or got a djetro with instruction booklet that can help me out?
I would like to know this also. Not that I want to run the Apexi BCK, but rather take a boost signal into the PFC for display on the HC and for logging on my Datalogit.
the boost control port on the ljetro and djetro PFC is the same
its most likely the 3 pin socket version that you have as the GTR has its own solenoid wire on the loom.
the djetro map sensor kit simply needs power that it piggy backs off the boost control port. you can see in the PFC how it is connected when using the boost control kit and the djetro kit.
i have used the pFC boost kit and it works like any other boost controller. you set the target boost, set the gain and thats it. make sure its give you the level and ramp rate you desire and its done. there is nothing more to boost control that i can see ? unsure why u would call it featureless or unstable. you set the boost and thats all there is too it.
its around half the price of the avcr and does the same thing
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
