Well there wasnt much interest last night....i was able to get 14 runs in, talk about value for money. I was really happy with my times, averaged 14 flat all night and best et 13.8. Im happy with this as my 33 is stock as a rock except for an exahust. it has 169rwkw. I was running on my 19" as it was a late decision. How does this time go against others?
https://www.sau.com.au/forums/topic/142410-wsid-tonight/#findComment-2654038
Hey that's pretty damn good times for stock - good on ya mate!!! I haven't run mine (yet!!!) but would desperately love to, just gotta get up the courage!!! ha ha ha!!! My last dyno run was 177rwkw with a slipping clutch which I've had replaced since so I would expect/hope for high 13's...???
There's a few of us Coasties heading down tomorrow night (Friday) to check out the action providing it doesn't rain of course! Hopefully will get to see some good runs and pick up some hints/tips! :whistling:
https://www.sau.com.au/forums/topic/142410-wsid-tonight/#findComment-2654447
s2ky...yeah i was chatting to one of ur mates, the type r. I ran against the gtir, damn thing beat me....damn 4WD launch...started pulling back but wasnt going to catch him. he was running low 13's. what time was ur mate in the r32 doing?
https://www.sau.com.au/forums/topic/142410-wsid-tonight/#findComment-2654542
yeah i didnt expect 14 runs...i went because i thought it would be dead and it was very dead...14 runs and i left at 9:40, my last 4-5 runs were continuos, racing around the back as fast as possible. might pop out to spectate tonight....
https://www.sau.com.au/forums/topic/142410-wsid-tonight/#findComment-2659604
The last 2wks at wsid have been extremely quiet because the weather has been terrible. Both wed nites it has rained the day before and on the day only fining up late in the afternoon. So majority of the more serious people won't even bother.
I'll be out there again tonight spectating, hell been at the EC Circuit all arvo spectating the NSW vs VIC guys so now its time for some more spectacular drag racing :rofl:
https://www.sau.com.au/forums/topic/142410-wsid-tonight/#findComment-2660172
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
