R32 Rb20-rb25 Swap Info Please....
Guest Allen Petersen
Got an 91 R32. I got the series 2 RB25 in the car and my wireing guy is not here and I wanted to cheak on how to just do it myself for a change. Looked for an hr or so and came up with nothing conclusive.
I dont need to know how to take out and put in stuff. Just the wireing for the relays, eng harness ect. Any info that will help me get this job done will be great. I have workshop manuals for both R32 and R33 but im not the wire god so the info you guys would give me will atleast be an assett. Help me out guys!!! :(:)
https://www.sau.com.au/forums/topic/142634-r32-rb20-rb25-swap-info-please/
In short, you need: r32 pinout diagram and engine loom, r33 pinout, wiring diagram and engine loom, multimeter, stanley knife, masking tape and a pen.
trace and label all the wires running to the under dash plug on the r33 loom, then chop off the plug.
trace and label all the wires running to the under dash plugs on the r32 loom as well as the main power plug in the front corner of the engine bay, then flog these plugs off the loom and transfer them onto the r33 loom.
Once you start labelling you will see the sense in what i'm saying.
Remove the wiper plug and box thingy from the r33 loom and splice the r32 wiper plug into the r33 loom (it's easy when you get it stripped out of the loom and look at it).
Strip the knock sensors out of the r33 body loom and use the r32 one on the rb25. It saves problems with hooking into the r32 fuse box later.
And then you have the assorted odd wires left dangling which generally require switched power like the air con idle up solenoid which can be wired in with a relay to trigger off the AC on wire, and the VCT solenoid which just needs a switched ignition source.
You may need to wire in the r32 dropping resistor for fuel pump speed depending on which version of the r32 loom you have as well as a temp sensor for the climate control.
I can't think of anything else off the top of my head. I'm colour blind so don't know colours either, hence the fun of tracing.
If you haven't done wiring before but can read basic circuit diagrams allow a good day and be patient.
I tried to find a pic of a partially complete s14-s13 loom i did recently to give you an idea of the mess you should expect but i think i deleted it in disgust :(
Good luck
Edit: oops, you also need a soldering iron, solder and electrical tape plus an extra relay and crimp on terminals.
Edited by BHDave
that sounds like a damn good idea. I will try that out. My manuals are all Japanese so translating them will be a pain but Im sure I wil figure it out. Your idea of tracing it sounds nice and simple. I also already did the wiper motor today and know exactly what you ment. Same thing I did. Thanks for your pointers
If anyone thinks they can add let me know! Thanks everyone!!!! :(:)
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
