as stated wrecking R31 4 dr skyline 89' TI model:
luxury model, electric windows, mirror, factory nissan bodykit, velour interior, 15' alloys, RB30 engine,
car had only done 160,000km so most parts in very good nic. also has the hotplate type tail lights but 1 has crack out of the outer cover but most people pull these covers off anyway.
*all parts cheap in QLD. just pm me and ill get back to asap
can freight all smaller type parts through australia post or courier if needed, cheers. :P
https://www.sau.com.au/forums/topic/142788-wrecking-r31-ser-2-skyline/
