Guest Josho
A Exhaust Control Valve allows you to control the loudness of your exhaust sound. The ECV is installed right after the catalytic converter, and adjustment of the valve is done through a cable run from the ****pit to the valve body.All you have to do is slide the lever installed in the car to get the appropriate sound.
Picture of a ECV
They range from $300-$400 a piece
oh ok thanks for the information and the picture. in the option Fan magazine, i saw that their is electric controller that control this Valve, (i think is the new product) am i right ?
is that needed on the car or it is useless?
by lowing down the loudness, will this effect the power as well ?
I have one (uninstalled) .... The car came over with it on and I specifically requested it be removed during the compliance. Pretty much it's as simple as it looks, you have a little plunger device in the car, you pull it and it reduces the flow of exhaust, push it back in and it sits horizontal.
My main reason for having it removed it that I could imagine passengers playing with it and me not noticing and then ripping it up the street .... backpressure not good for turbo :)
I still have the plunger in the car for show just so people ask what it is :D
Peter, not 100 % sure what you're trying to say, but you'll find the ECV is open when horizontal, and closed when vertical. So you just can't keep it closed for a long period of time or whilst fanging it hard .... or better yet, don't have one.
The reason people get a 3" exhaust in the first place is to remove back pressure. Instead of getting ECV's people should just hang on to their stock exhausts.
There is a guy (from around Newcastle IIRC) who makes a more advanced version of these, which is electronically and vacuum operated. It can be set in various ways, so that at low speed it is more closed, resulting in a nice quiet idle when required, and then when you hit it it will open up to allow unrestricted flow. This is all configured for your vehicle, so it does its own thing. It then has an override mode which allows you to have it stay closed at a set point so that if you you are subjected to an emissions inspection, it does not snap open when they rev it.
On a high-HP car with a big exhaust this is a pretty good idea, I reckon, as it allows a compromise between being able to drive around without worrying about being defected, and having no restriction when you want the least amount possible.
I believe AutoNerd did an article on it some time ago, I think that's where I read about this one. Looked pretty trick.
EDIT: Link:
http://www.autospeed.com/A_0883/cms/article.html
Tex
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
    • If you want the screaming "weeeee" sound, just let the gasket between the exhaust manifold and the turbo break a little. It'll go "weeeeeeeeeeeeeeeeeeeeeee" everytime its on boost...
