  • 3 weeks later...
  • Replies 40
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
hey mate, would you have a AAC valve, charcoal cannister or wiring loom? PM me
No sorry went with the top half of the manifold.
Offers being taken on the block and internals separately
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
