Hi all
Does anyone know:
1) what size bulbs are behind main dash for speedo, fuel, water temp and tacho? and how many?
2) what size bulbs are behind the centre meter cluster? and how many?
3) what size bulbs are behind the aircon unit? and how many?
4) also are they bulbs you can simply replace by popping out the bulb and putting in a new one? note: I mean popping it out of the holder and putting purely a bulb back into the old holder.
Someone has said that they are T6.5 bulbs, but the actual T5 glass bulb part can fit into a T6.5 bulb holder.
Thanks
https://www.sau.com.au/forums/topic/143272-er34-gtt-lights-behind-dash/
im pretty sure the main cluster globes and the triple gauge cluster are t-5, but i modified mine to t-10
attached are picks of the globes from the climate control unit. i dont know the size but they are tiny. i modified them also to fit small LEDs in there.
it was a while ago i did this, but im pretty sure ther are six globes in total on the climate control unit. in the pic attached you have to also unscrew the section i have put a line around(it is tricky because of the hot/cold dial and the surrounding plastic) and the other thre globes are inside that section.
thanks
Justin
walkoau: any idea how many T5/T6.5 bulbs needed in the main dash? and the centre cluster?
Is it 4 for the main dash and 3 in the centre gauges?
Thanks
yep 4 in main cluster and 3 in triple gauge cluster, but i modified mine so i got 6 in my cluster.
  • 4 weeks later...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
