Ok this car was for sale on here a while ago..I had a buyer but the deal fell through because the buyer coulnt
get finance..The car is immaculate..Its got
Twin plate
N1 spec turbos
HKS remote oil filter and cooler
Coilovers
Re-chipped ecu
It is a white 90 model..DEAD STRAIGHT..Not a scratch or dent on the whole car.76xxx kms which i think is true due to there being practicly zero wear on the steering wheel,pedals,seat,carpet etc.
pics at www.carpoint.com.au/used-car/NISSAN/SKYLINE/New%20South%20Wales/2181985.aspx
For more pics or info just pm me.
$20500
Edited by rbs30
https://www.sau.com.au/forums/topic/143851-r32-gtr/
  • 4 weeks later...
Hi mate,
how U go with the sale?
How about this mate plus cash my way
http://www.skylinesaustralia.com/forums/in...howtopic=148177
Thanks
I called about the car and apparently it is off the market now as it has spun a bearing.
https://www.sau.com.au/forums/topic/143851-r32-gtr/#findComment-2779955
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
