Ive just had my car retuned and is now making close to 400rwkw. I raced it at the drags here in Tassie on Saturday and smashed 3rd gear. What would be the best option for me now. Auto or manual. I dont mind spending $$$$s aslong as i can get something strong. Boost comes on real hard at about 6000rpm and with the manual it comes off boost when changing gears. What ratios are the standard 33 gts-t box???
https://www.sau.com.au/forums/topic/143998-gearbox-need-help/
r33 ratios
1st - 3.2
2nd - 1.9
3rd - 1.3
4th - 1.0
5th - 0.75
if you were just interested in quarter mile times go the auto, if you like to throw some track days, sprints, mount climbs in then stick with the manual... helical cut dog box, close ratio..... check out ppg
Holy jebus thats some horrid lag for only 400rwkw... :P
I take it its a drag only car?
Because you couldnt realistically run that on the circuit..
So... Its auto/transbrake setup for you dude with response like that.
Cost you around 4-5k for box to be built + installation, i dare say it'll have you be sent over to Vic (the auto) and built by a good place over here
cheers
Its still only a 2.5 and will be used on the street all the time. I wanted something different and wanted more power so i changed to this from the old TD06 setup. The engine internals are still unknown as to whats standard and whats not. I want to see how far you can go with a 2.5 before i built a 3lt bottom end.
Street all the time? hmm...
Im afraid no gearbox will really "help" you for a street application. You only have 2000 RPM that your actually on reasonable boost.
An auto will possibly be better, really depends on gear ratio's and what not, im not expert there so i wont buy into that one :)
2000rpm power band really doesnt give a lot to work with dude, even then, the power figure is probably over stated by around 30rwkw, if not more.
Manual/Auto, whichever it is you wont (IMO) stop the "drop off boost" that you have now... short of using some nitrous to bring it all on earlier.
Maybe cams & an agressive tune might help, but its going to take a lot of time and R&D to get it working any earlier.
I suggest ring around some places in Vic that build auto's and see what they can offer.
Be sure to tell them the setup.
Should have chosen a t04z :(
Least you would have boost arond 5000rpm for the same power.
The car was tuned in Tassie and was a pretty cold morning. It was on the dyno for about 3 hrs and did 30+ runs. The cams are Tomei not sure what sive and the gears are still set on zero. I will try changing them next time.
As for the T04z thats what everyone else is doing. How mant twin turbo 2.5 are getting around???
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
