Hi all,
It's on again :)
When: Sunday 17th of December
Meeting point: Speers Point park 10am (leave 10.30am sharp)
Destination: Soldiers Point boat ramp carpark
The plan: Meetup at Speers Point park at 10am, then cruise up to Soldiers Point for a BBQ lunch, and happy snaps.
After that we can either cruise back into the forshore or just head home.
bring a small eskie with your lunch and drinks etc. in case we cannot find takeaway or something :(
Ian is bringing a BBQ, so bring something for that if ya want....
PLEASE CHECK THIS POST THE NIGHT BEFORE CRUISE FOR ANY LAST MINUTE CHANGES
Please let me know if you are coming, and i'll post up the names, cars etc.
Cheers,
Chris.
Attending:
NYL83R - Chris
d-d - Dave
dean1285 - Dean
monkeykplunk - Ian
bec070 - Bec
BLACK WARRIOR - Luke
E.k - Dean
AL53XY -
wizard2k - Josh
DiRTgarage - Paul & Stacey
jtrb25 -
RaZieL - Andrew
Tinks + 5-6 coasties :)
WE-11-SE
JT25RB - Joe
brizzi - Pete
GTRsean
miiz_skyline
Maybe's
burnsie - Brendan
DRAGTS - Ben
so i'ts still on....so don't forget to bring:
1. Umbrella
2. Lunch
3. Sunscreen?
4. Full tank of fuel
5. UHF Radio
6. Christmas Cheer!
  • Replies 89
Posted Images
Sweet, Im in for sure :(
So is a mate & his 33 (the white one from last year with the GTR kit & gold Simmons rims) - AL53XY
And I'll let the 31 club know NYL83R, thanx.
Edited by E.k
hmmm.....do you mean speers point or soldiers point? it's pretty much been worked out for soldiers point. unless someone has a better suggestion....
not sure if we will have a barbie available. i'm don't know the area good enough. the local park might be a bit crowded, so the carpark we are going to (Boat ramp, Everitt park) might be our best option .....maybe everyone can bring some lunch or we can do a fish and chips run when we get there.......
what do other people think?
My mate runs the Caravan Park where we were last year so if we are in need of a BBQ i can arrange we use the facilities there or there's good shade and BBQ's at nearby Spencer Park at the tennis club, Everitt park is not really a park...more a bushy hill....BTW we are in!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
