Bloody Hicas!
I had the same problem, so i opened the power steering fluid, made sure the filter on the stick was clean/not impeeded, swirled the fluid with the stick, and gave it a top up. No light anymore. give it a try. Would not have anything to do with boost.
https://www.sau.com.au/forums/topic/14451-bloody-hicas/#findComment-293324
Screw the diagnostics...Remove the hicas altogether...I promise you the cars handling will astound you without it...If you are intereseted I can supply a rear replacement bar out of chromoly for a very reasonable price...You can have a look at my car at some stage if you like.
One of the best things you could do for your handling.
Cheers,
Russ
https://www.sau.com.au/forums/topic/14451-bloody-hicas/#findComment-296567
haven't seen the r31 ones before but they are very easy to make, Have to have a look and a measure...thats all. Is it hydraulic like the r32?? I also took out the lines and capped the pump up the front....It never shows as an error etc and the fluid just circulates around like normal....
cheers,
russ
https://www.sau.com.au/forums/topic/14451-bloody-hicas/#findComment-297354
Only because it masks inherent problems, like chronic understeer...once you set it up and have the hicas removed it is much faster around the track...
Also much less weight and less to go wrong..I know its small differences but it all adds up. The car feels much more direct and respnsive to throttle steer without hicas.
Anyway, each to their own...Just make sure you drive both before you finally make up your mind.
Cheers,
Russ
https://www.sau.com.au/forums/topic/14451-bloody-hicas/#findComment-302072
I would suggest if you are happy with your car then leave it as it is...if you are not then you need to decide how you drive...do you drive hard..not so hard?? What other suspension mods do you have or are you prepared to do...
Give me a call if you want..pm me and I'll let you know my number, I can probably help you to decide.
Talk to other people who have and those who have not and see what they have to say...read these forums...heaps of threads with people who have problems with hicas..one thing is for sure no hicas is no worse.
Cheers,
Russ
https://www.sau.com.au/forums/topic/14451-bloody-hicas/#findComment-302142
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
