Ok guys, i have posted a few questions in regards to this before but need some more advice, there is a very limited knowledge of this stuff in the NT.
Firstly Car Mods
Rebuilt Motor (In Progress) RB25DET
Arias Forged Pistons
Eagle Rods
Cometic Metal Head Gasket
Tomei 256 Poncams
Tomei Cam Gear
Greddy Inlet Plenum
Garrett GT30R Turbo
Bosch 040 Fuel Pump
Nismo 555cc Injectors
Nismo Adjustable Fuel Reg
Apexi Power FC
Now we are looking for 300+rwkw
The car currently has the stock ECU etc.
(1) Will it be safe to bolt everything in once the motor goes back in, like injectors, fuel pump, power fc etc & run it around on the base map on the power FC to run in the motor for the first 1000km. The reason i ask is i have spoken to two local import mechanics up here, one said bolt on the new turbo & run in the motor on the stock computer, the other said the stock computer will shit itself with the cams.
(2) How strong is the R33 GTS-t running gear, ie gearbox, tailshaft, diff, will it handle 300+rwkw.
(3) I have seen alot of skylines with this power running multiple fuel pumps & surge tanks etc, but i have been told the 040 will be fine, is that correct.
(4) Anyone know if i have overlooked something.
with regards to running it it, it should be fine for only 1000km untuned.... you only have to bed the rings in etc but your cold start and running will probably be shyte. Should just run it in on the dyno
Will the Bosch 040 be sufficent for 300 to 320rwkw, i kind of want to do everything at once and never touch the biatch again lol :mellow:
from my experiance this method gives the best result.
100 kays of light duty reving. (traffic but not much ideling)
drop oil. and filter
500 kays of "normal driving" on low boost with shit oil.
drop oil and filter
next 500 kays of normal driving with a resonable oil of the same viscosity as what you want to run. on moderate boost. say 1 bar.
so after 1000 kays its readdy to rev and be given a hard time. dont drop the oil for 2000 kays.
after that its gonna be bedded in nicly. and not use oil or blow smoke or have heaps of blowby (depends what clearances your running)
at no time should you limmit revs to a pathetic 4k. if you do that you run the risk of scratching the bores one you rev it up.
what happens is as the rings bed in a very small lip is formed at the top and bottom of where they run.
and as you rev it the rods stretch a tiny amount. efectivly making the pistons travel further up and down.
if its only used to 4k for 1000kms and then give it a bootfull the rings will get dammaged.
so after the first 100 kms slowly bring the revs up to your max revs over a period of around 150kms. once yove eased it in to that you need to just drive it normaly and give it some moderatly loaded revving. like back to second to overtake etc etc.
for a referance our race civic motor we put it together and installed it. started it up,bled the coolant and went straight to the dyno.
after 10 mins it was hitting 9 grand without issue. doesnt use oil,no blowby and doesnt turn the oil black in 1 race lol
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
