  • Replies 180
yesum I did, your mags are in the mail
just to confirm (if I haven't before) I have payments from:
GoldZilla, foznice, Manwh0re and MyRush.. and someone who deposited $87 at a bank in Murrayville or Carnia in VIC (don't have a reference)
Awesome, thanks dude!
hi shan
i'm down for GTR no. 5 (Vol 109) and R32 GTR (Vol 56)...but can u wait until the 18th when my money comes in???
if so...plz PM me the payment details....thank you
I'm doin a run towards the end of the month... I will probably have some spares of Vol 109 from the current run, but I'm not so sure on the vol 56... so might have to put it in that run.
yeah its in the mail for you dude... its the green one with silvia written on it in the pic. You should have it on monday seeing as you're in VIC too.
Shan, have you posted the mags out to me yet? If so, what day, please? I still haven't received anything, should I be ringing my post office?
Shan, Paid today, PM sent. :mellow:
Hey Shan, paid for volume 24 today. PM sent. Thanks. :thumbsup:
I don't know about anyone else but i'm starting to get a bit frustrated, theres a lot of people wanting refunds ect in his Jaycar group buy too. :cheers:
Whats going on Shan ?
im not frustrated yet, but im abit worried now that u say that people want there money back from the jaycar group buy.
Shan can u please PM me if there is a hold up on the magazine, just a common courtesy to tell people what going on with there orders
