  • Replies 612
Yassanova - Electromental 2007.
Experimental electro mix.
http://www.megaupload.com/?d=F1ZBRQMA
enjoy.
Cant think of the tracklist off the top of my head so if you like any songs you dont know the name to just give me the mm:ss and i'll listen to it again and dig up the name for you :blink:
^haha got that song on my comp - funneh as
listening to old school classic
roxette - she's go the look
gemma ward vid clip (gemma ward=hot and she is a perth girl :unsure:)
http://www.youtube.com/watch?v=8tRWNjI8xLc
  • 3 weeks later...
The peaceful silence of the Kalamunda hills. Been house sitting for friends who live near the hwy in the suburbs down the hill. Back home to the relaxed hills tonight :( mmmmm relaxed
