Hey guys i recently acquired a set of HKS Hiper D's with buddy club springs on the rear which are approximately 8kg (dont know the proper unit for it). I plan to fit it to my 32, but the thing is i actually got them by mistake, assuming they were Hipermax II's. I have never took my car to the drags and i dont really plan to, my main focus is on circuit racing. I dont plan to join any competitions or the like, just a track day every month or 2. I know the Hiper D's have been developed for the quarter mile, with retarded dampening mainly on the rears. I also understand that this will give the car a funny feel while on the limit, with the suspension having a laggy feel to it. However, I dont really have the finances to buy another proper set now that ive got these unless i sell them.
The thing is id rather keep them for my own use IF they will give me a reasonably substantial upgrade from the stock shocks while on the track. What do you guys think? Not even worth trying them on at an upcoming track day? Will they instead hamper my performance on the track? Or maybe a rather good set, obviously not as good as a set of Hipermax II's, but still some good suspension overall and still worth using? I know this is all my own fault but any help or opinions are highly appreciated.
Cheers guys
Edited by Yawn
https://www.sau.com.au/forums/topic/145031-hks-hiper-d-hiper-damper-drift/
I'm fairly sure that the Hiper D's are aimed at drifting and the ones aimed at drag are the Hipermax Drag. Should definitely be better than stock suspension, maybe a bit oversteery?
Eh? Really? Hmm.. How come I cant find much info on it anywhere? :S
Also, which are the rears? The longer ones? The fronts are the onse with bigger pillowball mounts am i right?
If the above is right that means the fronts have got higher spring rates (ie. harder than the rears) and the rears have got progressive hks springs. Does that sound like a drift setup? I personally thought that sounded like a drag setup but i know nuts when it comes to suspension heh.
Cheers
Yes the longer ones are the rears. Usually you will have stiffer springs in the front for FR cars, as there is more weight in the front to hold up. From what I've seen, the HKS progressive springs incorporate a helper spring which completely crushes down with the weight of the car on it. It is just there to keep the spring trapped at full droop.
If you want to tell if it is a drift or drag setup, go have a look at the measuring spring rates thread. Measure you're springs as per the thread, and post the measurements there, Gary will work out the spring rate. Drag setups have spring rates around ~4/3kg/mm, where as drift setups have much higher spring rates (usually at least 8/6kg/mm)
Cheers mate, just checked, theres certainly no helper springs beneath the progressive springs. I just did my own shitty measurements, using a crap ruler, but i tried to be as accurate and careful as possible, and after that did the calculations on http://www.proshocks.com/calcs/coilsprate.htm that i found from that thread. I have no idea how to measure the progressive springs spring rate, but the fronts are roughly 5.5 kg/mm, albeit not hks springs anymore, their buddy clubs. Sounds like the fronts have been set up for circuit to me, no idea bout the rears tho. From what I think, the fronts were softer before and the springs were changed to ones with higher spring rates, what do you think?
Cheers for the help so far
Oh and update, I was looking around searching for hipermax D's and they look nothing like what i have. The lengths are totally different and hipermax D's have this special mounting thing on the side, which I doubt is car specific. To tell you the truth from all the pictures ive seen, mine looks like the usual hipermax II's the most, just that the pillowball uppermounts arent anodised purple, their just normal silver and the fact that my set has stickers on the lower part of the suspension that clearly say hiper d. But could it stand for hiper damper? It looks like the whole range of hks suspension has that exact same sticker tho. However, I cant confirm what any of those stickers say (besides my own) coz their too small. Can anyone with a set of HKS suspension advise?
Cheers
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
