bad bad bad!!
is it from the radiator? or from the block?? If it is from the block it could be a busted head gasket and its going to cost big $$$ If you continue to drive it you will warp or crack the head resulting in even bigger $$$
If you are lucky.. it is just busted radiator, or split radiator hose. Not that you should be driving it in this condition, but pop the bonnet.. you should see steam shooting out from somewhere - which will narrow it down. If you are lucky it will just be a hose.
My recommendation is not to drive the car at all until you can work out the problem. It most likely is quite serious.
Temperature problems can be FATAL to an engine..especially a modern engine.
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296076
got your PM pred and thankyou for your help... damn, now im shitting my pants, don't know where exactly it is leaking.. i looked under the car and it has the black shield covering under it so i couldn't tell whether it is the hose, or the block but it is defintely 100% coolant(green liquid). Just went down to the local mobil petrol station and brought some radiator stop leak treatment bottle.. going to add it and hope it helps.. :D:(
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296330
Guest RedLineGTR
Check the hoses, or remove the cover. Just follow the hoses down to where they end like the bottom one see if there is any fluid leaking. Best Bet is jack it up and take the cover off. I could be the water pump (how many k's) some of them go early before 100k. Or could be a cracked radiator as suggested above. (which is alot less common).
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296580
I'll put money on it being your water pump. Check the water pump, there is an inspection hole that will allow coolant to slowly leak when the pump seals shit themselves (telling you it's time to replace the pump). With the undertray in place you'll never be able to pin-point the source of the leak. The tray comes off easily.
If the pump is the cause you're up for a new one, & you may as well replace the timing belt while you're there. You need to take the same bits off - so why do it twice?
New pump from Nissan (same as RB30 VL pump) - $90-100
Timing belt - $80-90
Labour - ~$150 (dunno' exactly on this one?)
I very much doubt it'll be a major problem, so don't stress too much :)
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296690
Originally posted by pushead
I topped up the coolant in the white bottle as well as the alternator last night
Alternator - coolant? WTF! Coolant & the alternator don't mix well dude!
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296695
???? so you put water instead of coolant in the alternator? i followed a black hose which goes to a white bottle(the backup bottle) which labels coolant.
Checkout the attached Picture:
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-296768
you lucky bastard :D with the temp that hot ur lucky nothing blew
mine ran hot once and blew the seals on the plastic radiator end tanks - goodbye radiator
the water pump is a c*** to get off cos of the crank pulley bolt. you will more than likely need a rattle gun to get this off
the water pump may not be dead, it my just be the seal, in which case pull the pump off, put new sealant around it (doesnt use a gasket) and put it back together
you can drive around with a leak BUT make sure u keep the system topped up
if it starts sucking air or depressurises it will overheat again and u may not be so lucky
take it to a mechanic and there are pressure tests you can do on the radiator so check for a leak/crack. you can also run a test to see if there are exh gases in the system (leaking head gasket) so you will be able to pin-point the problem
just finally, cooling systems are ****s to work on and fix, if youre going to repair it make sure u do it right cos its the kind of thing which if not done properly will cause alot of headaches
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-303732
I would say this is invaluable advice.
Our pumps are cheap which is good.
You want to do pump, timing and accessories belts at once to save labour.
$150 for labour is damn cheap though.
T.
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-304054
I paid $350ish (think it was 350? Certainly under 400) for a new genuine Nissan w/pump & timing belt. Both installed. Thanks Vince (Rigoli).
I didn't want to take any chances so I got them both done. That way I knew they were new :)
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-306926
I very much doubt it'll be a major problem, so don't stress too much :P
Thanks for your detailed info dude.. really needed it...yep. same as the RB30 VL pump.. what hole are you refering to which you can tell the water pump shit itself?.. i couldn't seem to find it.. is it near the fan belt?
https://www.sau.com.au/forums/topic/14512-tempreture-is-hot/#findComment-310998
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
