  • Replies 562
Posted Images
They look tops andru .. Exactly like mine too .. Sweet I can expect them soon woot :P
Why cant you install them yourself .. Im sure you can give it a shot and if its not working see a fitter.. Im sure you'll save some cash that way!
i have no idea how the hell to rip the seats out or install anything. i just dont wanna make these seats look like crap, i heard that if u get it installed properly, thats when u really appreciate them cuz u cant tell the diff between them and the real thing.
and i have no time uni+work :P
anDru, are you in Vic?
Over here in SA, we have Whiltshire (sp) motor trimmers, if i didnt install them myself i'd go there. I'm sure there are similar motor timmers in your state, you could try the yellow pages and see if you can find someone close.
Rear seats are easy 4 bolts ..
2 at the bottom of the bit where you put ur ass at the far left and far right of the raise in the chassis..
Then remove that
Then remove the two bolts in similar places left and right at the bottom of the rear back rest .. screwed into that chasis ..
left up and pull back (you have to lift quite a bit..)
fronts just undo the bolts ..
Parcel shelf bend in half and pull ..
Side door thingos .. No idea get a pro i guess.
Now all you need is some time haha
yeah i reckon, if you take your time and pull the strings through like Trav33 said above, then they'll be all good
I'm thinking of cutting off my old covers and using the strings and contact adhesive to get a more snug and permanent fit
I prob wouldnt do that, What if they arnt so long lasting??
Anyone know where I can get the S and the R34 SKYLINE printed on fabric? I want to put the S on my head rests and SKYLINE on the back seats. like the GTR print up abit .. Im in sydney but what kind of company would I look at?
Edited by DECIM8
got mine!!
wats ur plans on installing em?
FAR OUT I NEED TO FIND SOMEONE TO ISTALL THESE, ive rang a few trimmers but they aint interested
Edited by anDru
im a lil worried about the creases of the seat covers after being in the box for so long.
man was bored so i started fitting the easy stuff onto the car, ffs these things are tighter then a 18 year old.
how da hell u put these things on and make em loook so nice. lol i sux at this
Edited by anDru
from what I read prior .. put them in the sun and the creases will iron out over the next week..
if you do install them also put them in the sun prior to installtion to make sure its softened so you dont rip it
man im just gonna pay some c**t 300 bux to do it cbf....im already tired and this is all ive done
LOL dun laugh its hard!!
JetDat - r mine ready to b picked up? or what's the # to call?
thanks...
0413 404472..
its good to see the covers arriving..
people please be very careful when fitting these..they are very tight for a reason!!!!!
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
