OK due to popular demand I've only this week made another 3 of these units....maybe I was just ahead of my time with them before :(
Anyway they're now priced at $40 + postage...damn inflation! I think though they're very handy as you don't have to think about pressing that annoying button!!!
If anyone is keen let me know.
Well my one is back in the car after 6 months of not having it (took it out when I was looking at selling the car, and someone bought my one off me)
I can't believe I went that long without it!!! No thinking, it's already off :)
  • 1 month later...
  • 2 months later...
More available :D
Remember it doesn't remove TCS, just defaults it to "TCS off" it can be turned on with a simple press of the TCS button (how it should be)
I am keen on one of these - great work. Have you got any left? I'll take some blue leds for the dash too! :P
Sure don't have it, they've got a better TCS system....the RB25DE :P
lol
lol
Can do mate, I'll PM dash pricing options as well :P
  • 2 months later...
Hey Mate, I understand that the RB25DE doesnt have a TCS control (or loads of power).... But will this device work with it to shut off the TCS anyway?
I'm just looking for a cheaper way to improve performance until i can afford my turbo upgrade.
Cheers!
Cheers!
It doesn't have TCS at all, this unit plugs into the ABS/TCS ECU in the rear of the GTt...your car doesn't have one.
  • 5 months later...
Do you have any left and how much would it be delivered to mt gravatt
We now make these to order, so yep can knock them up anytime $45 delivered for these now.
[/quote
how long do they take to make. Can you plz pm me payment details as i want to finish my tyers off before i get new ones haha
I'd like one please , could you let me know how long for delivery , does it come with install instructions (I'll need them) and could you PM me an Acc No so I can put the dosh in, I'm in Surfers.
Thanks,
Al.
Thanks,
Al.
can be with you early next week as I can get them made up this weekend, come with full install details (pretty pictures lol)
will PM details when I get home
can be with you early next week as I can get them made up this weekend, come with full install details (pretty pictures lol)will PM details when I get home
You have PM. sorry for the dupe request for instructions I sent it before I read this post, Cheers, Al.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
