2 mates managed to damage my passanger door not even 24h after having my car.
My car was stopped, handbrake up, mate went to get out, and the my other mate is his car figured he could sqeeze through on my left hand. Needles to say, when my door connects to the car (below the handle) is bent 45c for about 3/4 cm into the door. The metals are now pretty tight.
Ill post pics as soon as i can, though by the sounds of it, does this seem like something pannel beaters can repair? or would it be easyer to get a new door (is it hard to find 1 in good condition?) and have it resprayed and dropped in. If so, any ideas on how much the respray costs for a door?
https://www.sau.com.au/forums/topic/1457-new-door-needed/
Yeh i saw a few doors at around 200 each, just not sure of their condition. See my car was in 100% condition b4 this, and i mean all over, in and out. I don't want a new door, as its 'not the same' as such. I'd prefer to have what i have, repaired, but i don't like the odds as some of the metal (on the inside of the door, when it connects to the car) is abit crushed.
Im not paying for it, as wasn't my fault, though i just want a propper job done on it.
The door getting sprayed, 500-1000?
https://www.sau.com.au/forums/topic/1457-new-door-needed/#findComment-28732
ill tell u know the wrx doors dont takemuch to smash in... as i did it to my gf's parents my01 about 2 months ago.... all it did to my commy was a smashed tail light and a small scuff on the rear bar :mad:
but im lucky they only wanted 400 so it would cover itself on insurance, instead of me forkin out 1k or so when the door panel only cost 100 aparently
but man ur better off just to get a new panel, it will be alot easier and quicker than getting it repaired if its pretty damaged
but a pic would help maybe
https://www.sau.com.au/forums/topic/1457-new-door-needed/#findComment-29714
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
