i was wandering if someone could help me i started with a auto 2litre coupe i hav finished the manual conversion im halfway thru a body kit but am now on the search fore more power. i am not verry familliar with turbos but it is the rought i want 2 follow
if any1 has done 1 of these conversions i was wandering if they could explain the procces in detail including any problems with wiring i plan 2 use an apexi s-afc for the fuel maps but wasent totally sure what 2 du with oil pickups and cooling aswell as boost control plumbing
i hav searched but was unable to find any good detailed explanations
https://www.sau.com.au/forums/topic/145750-turbo-concersion/
