supadan - I wouldnt have a clue sorry, I've never sold a engine before... I would be thinking at least a couple of hundred as it would be a pallett.
Owgasm- Yeah I've had an offer for that price, but no money has been laid down on the table, Im giving the people who contacted me first pria to this offer being made the opportunity to buy it first. (If that makes any sense)
Edited by CameronBNR32
https://www.sau.com.au/forums/topic/145861-sold/#findComment-2725351
