hey people,
i need some help. i want to put a RB25 into my 32gtst at the end of the year, but i am not sure what series RB25 to go for, and i am not sure were to get a good price on a half cut or a engine and G-box package.
Any help with prices or phone numbers would be good (i am on melb). I also dont need a person that can put it in just someone that can get a package at a good price.
Cheers
Jonathan :)
https://www.sau.com.au/forums/topic/14599-rb25det-r32gts-t/
I'm kinda curious too... RB26DETT halfcut pricing? I saw $6000 being mentioned once..can you get them cheaper?
Can you still get half cuts? I thought with the new import laws they were making it impossible to import half-cuts to crack down on "chop and shuts" for imports??
Will they be possible in future? I'm thinking a year or so down the track... of something ... :)
https://www.sau.com.au/forums/topic/14599-rb25det-r32gts-t/#findComment-295780
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
