Originally posted by KILLER-T
I think it was bad tuning that cost me my last engine it cracked a piston ringland and cost about 5.5k to rebuild and before anyone asks who did the tune i wont tell because im not 100%sure if it was the tuning
Adam,
Out of interest, what were the symptoms of your broken ringland? Was it a major failure that was obvious (bang, smoke, noises that shouldn't be there etc) or a gradual thing? I'm guessing there was audible detonation?
Cheers,
Matt
Guest KILLER-T
Hi whatsisname i had no warning didnt hear any pinging had it on a dyno for a tune up drove it home got up in the morning poped the hood and i noticed oil had been spraying out the BOV and boost solinoid .Took the car for a drive it still had heaps of power. So i took the car to PSI performance and he tested the comp ratios and thats when i was told the bad news that i needed a rebuild
Good to see all is well now mate (many $$$ later).
So on the pre "bad news" test drive did it make any nasty noises? Anything else (other than the oil out the BOV & solenoid)?
Thought it'd be a good idea to get a bit of this kinda' info on the forum, for future reference.
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
