Hey everyone!!..
Got a question I'm hoping someone will be able to help me with..
I've just purchased my first Silhouette and was having a look around under the bonnet when I found a part just sitting there, not connected up to anything, or bolted/screwed on.. (Had obviously been taken off and left there under the bonnet previously..
I've had a look around the RB30 and can't find a plug that is homeless so I'm lost..
It's a module with "Nissan" marked on the front and has "JECS A22-626 911" marked on the back. It has a 3 pin plug at the bottom..
Would anyone have an idea to what this module is??..
Any help would be greatly appreciated..
https://www.sau.com.au/forums/topic/146648-anyone-know-what-this-is/
Nah, just replaced with an auto TPS and left under the bonnet by the look of it.. Had probs finding where it went cos i'm only new to the R31's and RB30's!!!.. All good now tho..
On saying that, I have a manual box and manual ECU.. Would running an auto TPS create any issues, or all good to leave it there??.. The silo runs like a dream so I don't think it is having a negative affect, but would like to be sure all the same..
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
