I have a little miss if I put the foot down hard and it comes onto boost.
Ofcourse, this could be coil packs on the way out, maybe the ignitors aren't strong enough, maybe its just rich and retard. I'll work towards that one in the future.
One thing I have noticed, which I find interesting, after I have this little miss at say 5,000rpm, the car sounds different aftwards. Not missing, just a little more fueled up. Few more pops for a while.
Also, I have blocked off the BOV outlet and run a POD. I can really here it whistle when its cold and just started up.
After a little miss, its hard to hear at all. At first I thought i'd blown the turbo.
Do you think when it misses, it increases exhaust temp and this is transfered through to heat right through the engine bay?
Do you think this extra heat is causing the huge difference in the way the turbo spools ( at least to the ear ) and changes how much fuel is being dumped in to combat that heat?
I ran standard boost and the car is standard.
https://www.sau.com.au/forums/topic/147018-post-missing-effects/
OK, well I'll assume it is heat then and a front mount and reduction of inlet temps will help spooling of the turbo.
Hopefully the SAFC helps it out a bit...
the intercooler well help drop the temps after the compressor outlet but if its sucking in hot air in the first place, its still going to be hotter
OK, but what I'm really wondering about is...
why does a few pops and a bit of missing from 4500-5500rpm suddenly make the turbo sound different and not want to build boost as fast???
then after a while, its very audible again and building boost quickly?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
