Hi all...
Have all r32gtr´s Srsairbags on the drivers side and hicas?
Cant you all list all of the original mods on your cars in this thread!?!
HAve on mine paper fron nissan japan and it says: Build year: 1994/8 And modell year of the car: 1995 and it have srs airbag on the drivers side and hicas.
Have heard the r32gtr doesent have this modds originally and it is weary rare to get!?!?! HAve i heard wrong?
Regards Klaus
https://www.sau.com.au/forums/topic/14719-r32gtr/
Originally posted by ylwgtr2
i have a gtr owners book with all build nos and dates at home in aust...will check wen i get there....but 95 r32...not right...theyy were not called 95 model,nor were they produced then
I can fax you the profe.... if you whant?
In the certificate from NISSAN JP it says: Build Year: 1994/8 And modell year of the car: 1995 Have allsow read in the net that year it would be special ordered R32GTR in the amount of 225 Build....
Im getting a really big suprise when i opened the paper from nissan jp.
:D :bahaha: ;)
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-298360
Originally posted by fatz
chassi number will tell the truth
pete
and some had airbags but they r shit (large steering wheel not much room for the driver)
It would be the smallest airbag done in a car, it is a gtr steering wheel in my car...
Yupp it would do that...
Cheers
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-298797
Originally posted by craz0
They go buy the first year it was registered so you will probably find that it was first registered in 95 but was made in 94.
Yes made Year is 1994-08 that have i said all the time butt NISSAN japan has sent all documents of the car to my contact over here at NISSAN Sweden and when i got it it says like this: (Once more) Built in 1994-08 and medell year of the car is: 1995 i dont like to be called to lie but its stand so in the paper of it, it is for real.....
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-298809
1 way to check...chassis no.....noone said your a lier....i think your missinformed tho..i have seen hundreds of gtr go to auction limited models,automatic gtrs...and have a database here in the office of the auctions all over japan....never seen a 95 R32
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-298838
No not called, ill whant you dont belive i am a lier onle.... =)
It is way strange beqause i had get the paper from Nissan japan and they should now their stuff... but i can have bin missinformd me to.... How can you chek this up?!
This modell should be one of 225 made... but how to se that then?
Regards Klaus
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-299278
Originally posted by KILLER-T
This is a bit odd to me because there is another dude on the forums that says that he has a 95 R32 GTR  and he is from Sweden aswell
It is the same person me and him =) On SAU is my nick: SkylineMannen and on SDU is my nick: Skyline Dude :bahaha: :bahaha:
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-300596
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
