SOLD
Nissan R32 Godzilla GTR V Spec II
White, fully re-built engine, highly modified car, thousands spent have all receipts, serious buyers only. Personalised plates, rego, perfect condition, very regretful sale.
$30, 000 Serious buyers only
ph: 0438 881 462 or PM me
I live in Brisbane
As to the list of mods, here are most of them:
Trust front mount
Twin 3 inch exhaust
HPC coated dump pipes
HKS 2530 turbos
Toyo T1R 235/40/17 brand new
G7 Panasport Rims
272 HKS cams
HKS cam gears
Ogura twin plate clutch
Sard 720 cc injectors
In tank fuel pump
Air water bypass/bleeder
Remote oil cooler and filter and speed flow fittings
Custom blow buy, speed flow fittings
Forged pistons
Brand new crank (R33)
N1 Balancer
N1 Water Pump and Oil Pump
O-ring block
reconditioned tail shaft
ARE radiator
Silicon radiator hoses (Blue)
Gates timing belt
Link ECU
Brand new head, valves etc
Alarm, auto windows up
AVCR
Autometer fuel pressure and boost gauges, on the piller
NGK iridium spark plugs
Runs Motul 800v oil
no air flow meters, runs a map sensor
Koni adjustable suspension
White leather inserts
Isotta steering wheel
Isotta windsceen wipers
Tinted windows
Big stereo, cadence Z4000 amp to run the splits, VDO HPC 1700 6.5inch splits
6 x 9s in the back
US audio bone crusher 1200w Amp to run the subs 2x 12inch
Battery in the boot
post-18869-1166173365.jpgpost-18869-1166173548.jpgpost-18869-1166173853.jpgpost-18869-1166173976.jpgpost-18869-1166174089.jpgpost-7721-1129008347.jpgpost-18869-1166174333.jpg
Edited by MYR32GTR
https://www.sau.com.au/forums/topic/147526-sold/
  • 2 months later...
Could you please list the VIN to enable confirmation that it is a genuine V-Spec II.
It doesn't have the V-Spec II label, rims, rear spoiler or front lip but you could have removed all of these items. It does look like it has the Brembo brakes though.
https://www.sau.com.au/forums/topic/147526-sold/#findComment-2969464
  • 3 weeks later...
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
