are we allowed to bring other ppl like dont have a skyline?
hell yeah! :) all are welcome! just tell them no crazy business! it'll be double demerits and plenty of cops will be out an about :) i love this run, and its kinda become tradition, so i'm going with or without an escort :D
Mona......lol......... i cant miss another wiseman ferry cruise!!!!!!!!!!!! want me to call the west boyz???.
BINTIE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :P no.. no you can't! ;) yeah! not sure if the westside forums are still going! but let them know :)
  • Replies 376
Posted Images
Mona... sorry wont be able to make it, i'll be cruising down from camping at Forster that weekend.
awww.. no worries pete!! how was your house party nye? we went up to coffs, so couldn't quite make it!!! twas awesome, but driving back yesterday was a killer :)
i have a friend in a pulsar that wants to come with.. if it's cool. put us both done please mona.. thanks
no worries!
ok im for sure now and ill prob have 2 others with me maybe more
sweet! :rofl:
im a maybe.. if you want me to be a definate, talk to chris.
man! where is (sur) when you need it!!! :P
now the question is - does everyone just want to head through galston (thats a given) down northern rd to wisemans, or do you want a semi windy and long detour?
windy and long is the way I like it :P:wave:
wooot! ok! means i'll have to draw maps for everyone!!! :P wonder if i have my template from 2 years ago! lol!
I will be there depending if my car beats yours outta the workshop!
hehehe.. get crackalacking cause my car is back! :laugh:
hey Moanie,
how you been?
long time no see
got a msg from mintie
and i hope a forester & a ford is welcome to your cruise
if so i will be there with Jo (goldilocks) & Dean (WIPLSH) if he gets out of bed that is
and afew more people from the west
see you soon
FOR SHIZZLE COLIN!!! :) its been aggeesss since i've seen you guys!!! And dean better get outta bed! haven't seen the red and purple beasts in a longgggg time!!! does jo still have her 180? :D
depending if i get my defects cleard il be pedaling
ouch!! what tha!! please explain! :( and you'll be scrubbing if not driving :)
if my wheel is fixed, then I'm coming along. anyone bringing a barbie? nothing better than a bbq after a cruise
thats an awesome idea! I know there is a picnic area, but don't know about bbq facilities! may check it out on this cruise and organise something for next time! If you're keen you can organise something james! :D:):D
FOR SHIZZLE COLIN!!! :) its been aggeesss since i've seen you guys!!! And dean better get outta bed! haven't seen the red and purple beasts in a longgggg time!!! does jo still have her 180? :(
na she sold her 180 and brought a mazda sp23
her 180 was going to blow up hahahahhahaha
cool i will see you there nice and early
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
