my stagea is still for sale i start my studying soon so i need the car gone to pay for schooling things.
1997 stagea S1
tein adjustables fronts, standard rears
85k
To4 turbo, 38ml wastegate, 3inch dump pipe, oil catch can
in very good condition
goes well
no problems
14,000k
pm or call me on 0409285451
im in sydney
Edited by tommyb
https://www.sau.com.au/forums/topic/148051-nissan-stagea/
it has a S2 motor just it just does not have the different front lights.
its an auto
mate ... thats a S1, thats not a neo engine (from an S2- well no neo cover anyways, but id be suprised if u jus ditched the cover) and thats def not a S2 front end, plus 97 sorry mate thats def not a S2 its a series 1 .
https://www.sau.com.au/forums/topic/148051-nissan-stagea/#findComment-2767471
ok whatever think what u want
its a s2 33 motor
this is what my mechanic told me
dane he owns dezyne motorsport cencetps
Edited by tommyb
https://www.sau.com.au/forums/topic/148051-nissan-stagea/#findComment-2767995
its a s2 33 motor
true it is.... a S2 R33 engine is what all S1 Stageas come with, the S2 Stageas came with neo engines same as the R34. It can be confusing but your car is a S1 with a series 1 Stagea engine, if you dont believe me or want a 2nd opinion post up in the Stagea discussion and gets some others opinions.
Sorry mate not trying to cause probs jus setting the record straight, you have a nice looking, modified S1 Stagea
Lee :)
Free Bump!!
https://www.sau.com.au/forums/topic/148051-nissan-stagea/#findComment-2768090
  • 3 weeks later...
  • 3 weeks later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
