my stagea is still for sale i start my studying soon so i need the car gone to pay for schooling things.
1997 stagea S1
tein adjustables fronts, standard rears
85k
To4 turbo, 38ml wastegate, 3inch dump pipe, oil catch can
in very good condition
goes well
no problems
14,000k
pm or call me on 0409285451
im in sydney
Edited by tommyb
https://www.sau.com.au/forums/topic/148051-nissan-stagea/
it has a S2 motor just it just does not have the different front lights.
its an auto
mate ... thats a S1, thats not a neo engine (from an S2- well no neo cover anyways, but id be suprised if u jus ditched the cover) and thats def not a S2 front end, plus 97 sorry mate thats def not a S2 its a series 1 .
https://www.sau.com.au/forums/topic/148051-nissan-stagea/#findComment-2767471
ok whatever think what u want
its a s2 33 motor
this is what my mechanic told me
dane he owns dezyne motorsport cencetps
Edited by tommyb
https://www.sau.com.au/forums/topic/148051-nissan-stagea/#findComment-2767995
its a s2 33 motor
true it is.... a S2 R33 engine is what all S1 Stageas come with, the S2 Stageas came with neo engines same as the R34. It can be confusing but your car is a S1 with a series 1 Stagea engine, if you dont believe me or want a 2nd opinion post up in the Stagea discussion and gets some others opinions.
Sorry mate not trying to cause probs jus setting the record straight, you have a nice looking, modified S1 Stagea
Lee :)
Free Bump!!
https://www.sau.com.au/forums/topic/148051-nissan-stagea/#findComment-2768090
  • 3 weeks later...
  • 3 weeks later...
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
